How to retrieve letterSpacing with Plugin API?
  • June 19, 2024
  • 5 replies
  • 146 views
Hello!
I’m trying to recover the letterSpacing value of a TextNode through PluginAPI. I’ve set some of my TextNodes to have a letterSpacing of 0.16px and others to 0.45px and I want to get that value in my Plugin.
However, every TextNode, those which have a modified letterSpacing and those which don’t have this value inside ‘letterSpacing’:
letterSpacing: {
unit: “PERCENT”
value: 1
Is there any other way of getting letterSpacing? I’ve checked and I’m retrieving the correct nodes.
  • June 19, 2024
I can’t reproduce. I set the spacing to 0.12px:
Can you share a test file?
The letterSpacing I’ve set:
The answer I get:
I tried isolating the TextNode in a different page so I’m getting the same node 100%.
I’m guessing it must be due to how / where the designer set the letterSpacing. We will check it. I tried to retrieve the TextNode using the Chrome Developer Tools as you did and I’m getting the same response as always.
Thanks
  • June 19, 2024
Is this from Dev Mode?
Can you show what the setting looks like in UI?
Exactly that, I just checked and that 0.16px is basically 1% of the fontSize. In the normal UI it’s set to 1%.
Thanks, you have been very helpful. 🙂
  • June 19, 2024
If you need 0.16 instead of 1% you can try using textNode.getCSSAsync() and it should return the value similar to dev mode https://www.figma.com/plugin-docs/api/TextNode/#getcssasync but I’m not certain, haven’t tested.
