Jeremy_Hesidenz
April 9, 2024
How to reset the scrolling position within a frame after swapping instances with variables?
  • April 9, 2024
  • 489 views
Hello. I have a frame which contains an instance of a component variant. The component has several variants, all of differing height.
When clicking one of three buttons above the frame (tabs) I use variables to switch the variant that appears within the frame. The issue I am encountering is that the variant inside the frame is preserving the scroll position of the previous variant, and I want the variant to always start at the top when it is swapped.
For example, in the GIF attached, variant #3 of my component in very long. I scroll to the bottom of the frame, then switch back to variant #2 which is much shorter.
At this point, the frame still thinks that it is scrolled to the bottom of variant #3, showing only white space because variant #2 is scrolled far beyond its actual length.
When attempting to scroll variant #2 after this, it “snaps” back into place because it realizes that the height of variant #2 is far shorter than the current scrolled position.
How can I fix this?
Figma_ONqkDFG893
Jeremy_Hesidenz
April 9, 2024
Anita2
May 28, 2024
Hello, did you end up solving this? I have the same problem!
