Romain FTV
Jul 31, 2025 1:05 PM UTC
How to preserve library links when duplicating a Figma file?
Hi everyone,
I’m working as a Design System Designer in a large organization, and I’m setting up a starter Figma file that Product Designers can duplicate to begin their work immediately, with all the correct libraries already activated (core components, design tokens, etc.).
The goal is simple: designers should be able to duplicate this starter file and start working without having to reconfigure or manually activate libraries.
I created the starter file in a shared team project and made sure the required libraries were activated. However, when someone duplicates the file (via right-click > Duplicate or Duplicate to Drafts), all the library connections are lost. Designers then have to go to the Assets panel and re-enable the libraries manually, which is exactly what I’m trying to avoid.
I also tried:
  • Placing the starter file in a shared project and giving “Can view” access → duplication still loses the libraries.
  • Publishing the file publicly in Community is not an option for internal reasons.
I considered using a plugin to check or restore library links, but Figma’s plugin API doesn’t expose the list of active libraries.
My questions:
  • Is there any reliable way to preserve library links when duplicating a file internally?
  • Could Figma consider supporting this kind of use case in future updates?
  • Has anyone in the community found a clean workaround?
Thanks a lot in advance 🙏
Romain
Kyle Schmitz
Jul 31, 2025 2:32 PM UTC
How do we have the same question within an hour of each other lol
Also looking for an answer here.
