How to make a shape forget it's been rotated
  • July 3, 2023
  • 10 replies
  • 8976 views
guillo
I am creating an ‘infinite’ photo gallery. Basically a grid of images in various orientations that extends in all directions. I am creating empty rectangles to make the grid shape and then have other people paste their images into each rectangle. The problem I am having is a lot of the rectangles were rotated so when the image is pasted into it, the image is also rotated.
Is there a way to make all the rectangles ‘forget’ how they have been rotated and just work as a regular container for the images?
thanks
Best answer by Tomas5
There is a workaround for “forgetting” rotation of the rectangle. Create new small rectangle inside the existing rectangle, select both rectangles, union selection and delete the small rectangle. if you now paste the image on Union layer, it will not be rotated.
Tomas5
  • July 4, 2023
guillo
  • July 5, 2023
Except I already have hundreds of rectangles laid out, so I guess this is a start-over for me. Thanks for the tip.
  • August 16, 2023
I selected and right clicked all elements I wanted to reset and “copied as svg” then pasted into Illustrator and the copied back. This set the bounding box of each element to only consist of vertical and horisontal lines, e.g forgetting the rotation of the elements.
  • October 23, 2023
Ctrl+E. Or click right mouse button and choose “Flatten”.
  • November 6, 2023
if you don’t want to flatten for some reason it seems that grouping again can do the trick
Elli_Vizcaino
But when you ungroup the rotated vector is still left the same. @micropoozz solution to flatten is what works.
Kylie_Jess
  • July 22, 2024
Thank you so much
Smittee
  • February 28, 2025
  1. Copy as SVG
  2. Paste in Adobe illustrator
  3. Copy from Adobe illustrator
  4. Paste in Figma
Wait for Figma to add 'Reset bouding box’ feature :-).
Martti Sirkkola
Oh man, this is the most annoying thing ever. When working with components inside components - not being able to reset the current rotation point is… it’s total chaos. I’m losing my mind.
Rachel_Pardo
  • October 22, 2025
None of the following works:
  • flatting the vector (cmd + e)
  • merging (union) with another shape (e.g. a square) and flattening both
  • duplicating the same shape and merging (union)and flattening both
This issue isn’t solved.
What works is to export the vector as SVG and put back into Figma. But that’s not how the vector should work, that’s a hack.
