How to lock drop shadows so they rotate with the object
  • June 17, 2024
  • 412 views
Hey all,
Looking for help or workarounds and how to lock drop shadows so when a object is rotated the shadows have the same orientation relative to object.
My last option is to dupe the object to create the shadows, but I really really don’t want to
do that as I want to make lots of iterations and chances quickly to many different shapes.
Thanks!
AlicePackard
Power Member
June 17, 2024
my suggestion was going to be what you described not wanting to do 😅 apologies. But! If your shape is a main component, you could use two instances of it to make iterating easier. One instance would have the yellow fill and black stroke, the other would be a black fill with a blue effect. Then, when you need to edit the shape, you can do that on the main component. I’m away from my keyboard at the moment so I can’t offer screenshots or GIF examples, but if you’d find that helpful let me know and I can come back with another reply later.
I write about building excellent Figma components on my blog: https://alicepackarddesign.com/blog
James_EtcAuthor
June 20, 2024
Thanks for you reply! Looks I’m going to have to find a different solution like buying a month of Illustrator - I have almost a hundred I need to figure out.
Marian_Brchan
June 20, 2024
If you know what the rotations will be (e.g. 0°, 45°, 90°,…), you can create styles for shadows and easily change them on the instances of the main icon component.
E.g. http://clippp.co/sharex/QxUqSUjLac.mp4
