Answer
How to create component text field to appear?
  • February 24, 2025
  • 679 views
Steven11
I’m working on creating a lot of components with text fields in them and I can’t figure out how to get the text fields to appear for an instance of a component within the Design menu. See the screenshots below of what I’m trying to recreate for an instance of a component.
I can set the properties so that it shows/hides the labels, but I can’t seem to figure out how to set the property to also allow me to change the text from the Design Menu like in the screenshot above.
Best answer by iago
Hey!
  • Select the text layer
  • under text settings (right panel), select the input and then click the icon next to it (apply variable/propriety)
  • Hit the plus icon button
  • set your propriety, hit create propriety
iago
  • February 25, 2025
Hey!
Steven11
  • February 25, 2025
Thanks so much!  I was using the appearance properties, not the text properties. Duh!
