Alex_FG
How to create a correct relativeTransform for objects?
Trying to apply several transformations in a row to a Figma object, including skew, and keeping the full working matrix (with correct scale values), how do I apply the final composite transformation?
I know that Figma objects don’t care about the scale in the relativeTransform and have to be resized using resize(). How do I adjust the transform to “remove” the scale but keep the correct rotation and especially skew?
In this picture I first scale then rotate, the points are transformed correctly, the rectangle and star are not. 😦
Here first I rotate then scale:
Here is skew. If that’s all I do, it works:
but as soon as I rotate the result, the objects and points do different things (the points are correct):
So, if I take an identity matrix and apply a bunch of transforms to it, how do I translate the final result to Figma objects?
Power Member
May 20, 2023
Can you please share the code you used for these examples?
Alex_FG
Alex_FGAuthor
Sure, it’s just basic transform code.
The transform function is
function applyTransform(obj, xform)
    // add to object's "total" transformation
    obj.xform = mulm3m3(obj.xform, xform);
    // apply only this transformation to the position (only for points)
    const p = mulv2m3(
        point(obj.x, obj.y),
        xform);
    obj.x = p.x;
    obj.y = p.y;
and the transforms are
applyTransform(obj, // move
    [[1, 0, x],
     [0, 1, y],
     [0, 0, 1]]);
applyTransform(obj, // scale
    [[sx, 0,  0],
     [0,  sy, 0],
     [0,  0,  1]]);
applyTransform(obj, // rotate
    [[ Math.cos(angle), Math.sin(angle), 0],
     [-Math.sin(angle), Math.cos(angle), 0],
     [ 0,               0,               1]]);
applyTransform(obj, // skew
    [[1,  sx, 0],
     [sy, 1,  0],
     [0,  0,  1]]);
Then, when it comes to actually updating the objects, I have two functions:
// figObj is the Figma object I'm updating, this is what is coming out wrong
// genObj is the generated object that I calculated
function setObjectTransform(figObj, genObj) // called for objects
    // make axis vectors == 1
    const scaleX = Math.sqrt(sqr(genObj.xform[0][0]) + sqr(genObj.xform[1][0]));
    const scaleY = Math.sqrt(sqr(genObj.xform[0][1]) + sqr(genObj.xform[1][1]));
    genObj.xform[0][0] /= scaleX;
    genObj.xform[1][0] /= scaleX;
    genObj.xform[0][1] /= scaleY;
    genObj.xform[1][1] /= scaleY;
    // do magic to make object transform correctly ???
    figObj.resizeWithoutConstraints(
        Math.max(0.01, genObj.width  * scaleX),
        Math.max(0.01, genObj.height * scaleY));
    figObj.relativeTransform =
        genObj.xform[0],
        genObj.xform[1]
function setPointTransform(figPoint, genPoint) // called for points
    figPoint.resizeWithoutConstraints(0.01, 0.01);
    figPoint.x = genPoint.x;
    figPoint.y = genPoint.y;
    // no transform here, points are already transformed at every step
    // so here I only care about their positions
mulm3m3() and mulv2m3() multiply vectors and matrices as their names imply.
So, every time I do a transformation, I update the object’s xform member (my own internal 3x3 matrix), but I also use just the current transformation to transform the object’s position.
On the Figma side, I use the transform if it’s an object and .x and .y if it’s a point. This way the points arrive correctly transformed and I can use them to test object transformation. Right now the result is not the same.
Maybe I’m not understanding the matrix thing correctly. Can’t I just have a complicated compound “final” transform applied to an untransformed object and have it do all the transformations in correct sequence?
Or, now that I think about it some more, do I have to keep an array of transformations, and then resize/transform/skew the object once for each transformation?
Alex_FG
Alex_FGAuthor
An animation shows what is happening much better:
As you can see, the points are doing what they’re supposed to, while the object is not.
Power Member
May 20, 2023
Thank you for the details! It seems like this is too complex for me to figure out, I hope someone smarter will be able to help. 🤓
I’m now also very curious about this thing: is this a plugin you are building? Or a widget, I guess? Looks very intriguing! I’d love to learn more if you can share the details.
Alex_FG
Alex_FGAuthor
It’s my plugin Generator (https://www.figma.com/community/plugin/899028246731755335), I’ve always planned for it to have geometry nodes, just now getting around to work on them.
You can see how it works here: https://twitter.com/brainshift_/status/1653677256504475651
But I want to keep objects as themselves as much a possible (keep text editable etc), and the transformations are stumping me a bit. Hope someone can help. 🤷
Power Member
May 20, 2023
Oh yes I’ve seen it when it was just released, it evolved quite a lot! 😍 Amazing work!
I’ve shared this post in the Figma Discord for visibility, hopefully someone can help.
Alex_FG
Alex_FGAuthor
Thanks for the kind words! 😀
Alex_FG
Alex_FGAuthor
Btw you can also work with text. 😉
twitter.com
Power Member
May 22, 2023
Epic stuff!
