How to clear “Used variables” that don’t exist in the file anymore?
  • August 25, 2023
  • 98 replies
  • 11993 views
Show first post
Jim_Knox
  • Active Member
  • October 8, 2024
doesnt work for me either,
  • October 8, 2024
Hey All, sorry for the continued trouble and frustration!
If the Detach deleted variables quick command does not work, the remaining ghost variables you’re seeing are still present because they’re still actively being used from collections within your design components and/or deleted color styles.
Be sure to review your file for variables that are being used across multiple pages. We understand how this can be confusing, especially when you have multiple collections with similar names and modes, making it difficult to differentiate between them.
Unfortunately, the team confirmed that we don’t have an automatic solution to fix this or a simple way to view which variables come from what collections. But in order to completely remove ghost variables, you’ll need to manually remove all instances of those variables from your file.
If you need help locating old variables that are still being referenced in nodes on the canvas and are able to share your file with us, please do so here: https://help.figma.com/hc/en-us/requests/new
Be sure to use your Figma account email, include a link to the file, share edit access with support-share@figma.com, and our Technical Quality team can help you locate and remove the old variables.
Saloni_Sinha
  • October 9, 2024
Same problem! Please find a solution to easily remove them completely!
Yeazey
  • October 11, 2024
i found solution with dead instances of used variables. First of all Figma didn’t respect hidden layers for “detaching deleted variables” as “reset variable modes in selection”, Figma also dont show hidden layer color in selected colors panel since hidden layers not selected.
Also this dead or old hidden layers across components forse Figma to show old/dead modes.
So to get rid of dead modes you need
  1. Select all in page
  2. Reset variable modes in selection.
  3. Detach deleted variables.
    wait till Figma did a thing and after that wait for Figma did all background updates.
  4. Check if “Dead mode” was removed (in my case it removed in 90% cases).
  5. if “Dead mode” still exist > look for hidden layers and remove them or reconnect to correct variable.
i get rid of Dead mode for about 30 min with this steps.
Enjoy
Rory_Pyatt
  • October 16, 2024
My ghost variables came down a button where I had deleted the master component, but had a modified version in my library. When I restored the component master, removed ghost variables, it all cleaned up for me.
But a more robust way of finding ghost variables would be appreciated.
jamiefang
  • October 16, 2024
I deleted every page, but there are still two ‘Used variables’ collections in this file. It’s really frustrating.
umer
  • October 18, 2024
The same issue here it is still in UI3. I tried the quick command but it does not work.
I am still facing this Ghost variable issue Does anyone know how to remove them? Will appreciate thanks
Schaefer_Christian_SGRE_TE_PPS
yeah it is kind of ridiculous that after 2y this bug still exists … some heavy flaws in the modelling here …
Paco_Lara
  • October 31, 2024
Please, Figma, Fix this issue. I want to copy components from a file to another and it’s impossible to make it without importing a full set of ghost variables. I’ve tried to use a “bridge new document” where I remove manually all the variables, and then, copy and paste the components in the Figma file I need… and variables are still in there. No makes sense at all.
Paco_Lara
  • October 31, 2024
I’m trying to be creative: I created a history version point. Then import the components, remove manually the variables of every single layer. Once all the layers have any link with any variable, copy all the components again. After that, I restored the history version I created previously and paste the cleaned components… And it seems to work but some layers are removed and don’t appear. It’s clear that you have a real bug with this.
amatawc
  • November 5, 2024
Hey, just to add to the pain point here: bringing in components from files with the same variable architecture will NOT allow the file-specific variables to overwrite the previous mode(s). Won’t see the local variables, on any level. First test was to try to apply mode in mass; the local modes were literally not available in the dropdown. Go to the most granular level and build up by applying the specific, new-file, updated-design variable, which then show up and LOOK right, will not reset what modes are listed as available or note the local variables are attached in Figma. Using Tokens Studio, and that add-on CAN see and CAN change and what’s developed out of it WILL work. It’s just Figma.
It impacts as I build, as others come in to use the libraries I’m building, as devs try to develop from the libraries I’m building, and as we try to ensure that tokens will be applied in production in a way to absorb design chances fluidly. It’s not a little thing. It really needs attention.
Mikael_Cederbom
Hi, as a Figma user I would like to easily detach all components, styles, and variables on selected frame (hidden layers included), so that I can hand over my design from one project to another without the risk to mess up a different design system.
Thanks! 🙏
Leter
  • February 12, 2025
Agreed, this is a must-have. Right now moving components from one design system to another is extremely messy and hard to clean up when using variables and styles across my component libraries.
Danielle_Flinn
I am also experiencing this issue in a design system library file – I spent over 2hrs of attempting to manually go through each page of the file and relink variables correctly, find hidden layers referencing other file variables and have barely made a dent in the issue. There really needs to be a way to “remove all variables not created in this file from all visible and hidden layers” option.
Better yet, being able to detect the variables that are being referenced and a way to map them to variables created in that file.
Travis Tinney
Although there seems to be a range of issues people are experiencing in this thread, some of them may be resolved with the aid of a new plugin I built that can help identify stray variables or components that are still attached to a node somewhere in your file. You may have to run the plugin one page at a time for bigger files for now (it can timeout on whole file scans if the project file is large). Hoping this helps some others like it did for me.
Stray Component & Variable Finder
Povilas_Reklaitis1
Finally, you solved it! Thank you!
Maya4
  • May 12, 2025
It’s not working for me. I have many text variables that I need to detach, but with the plugin scan I was only able to find components and not variables. The variables were brought in from the file called Website Refresh when I copied over some elements. What am I doing wrong?
Travis Tinney
If by ‘only able to find components’ you are talking about your second screenshot - The index library tab is used solely to ‘whitelist’ or ignore components and variables you don’t want to be identified as stray. So if the file that you are in right now ‘saltbox pitch deck’ does not have any variables created in it then it won’t show any on the index tab. If you are using the plugin to scan for variables in the ‘pitch deck’ file and it isn’t coming up with any results even though you know there are variables in it, then that would be an issue i’d have to look into.
Hope this help; if you are still having issues then maybe you can duplicate the target file, delete most of the content so there is only a small sampling of the text you are scanning that is not being recognized and share it and i can try and identify what is going wrong.
Aster_Ng
  • May 14, 2025
Finally removed ghost variables (manually check) – hope this helps!
Hi! Just want to share my experience dealing with ghost variables in Figma — those deleted variables that still show up in the mode dropdown even though they’re no longer in the file.
I ran into this while cleaning up my file. I deleted and recreated some variables, but found that old/ghost variables still existed in the dropdown.
At first, I went page by page to check if any layer was still using the old variable. But that didn't remove the ghost variable collection. I tried a few plugins and checked hidden layers too — because if a layer is hidden, Figma doesn’t show the variable info in the right panel, so it's easy to miss.
Page - Apply variable mode
Appearance - Apply variable mode
Later, I used the "Apply Variable Mode" tool. I checked each page — if the ghost variable still showed up in the dropdown, I clicked into each section, then frame by frame, layer by layer, until I replaced everything. It took 2 full days, but finally the ghost variable disappeared from the dropdown.
Luckily my file isn't too big yet — just around 8 pages with 6–7 UIs per page. I’ve only used Figma for 6 months (I was an Adobe XD user for 7 years), and overall I really like Figma, even though it's still a bit buggy sometimes (well… my product has bugs too haha).
My tip: If you're starting a design system, plan early and plan big. Or else you’ll end up like me… keep fixing and adjusting over and over 😂
Connie5
  • July 25, 2025
while i love the ingenuity everyone has shown with filling the gaps, whether they’re plugins or manually (and painstakingly) going through things layer-by-layer, this shouldn’t be the expected outcome for a tool that’s supposed to help us do our work? anyway, posting cause i don’t think this is solved because i have to actually involve support in my file to fix AND it keeps happening. please fix this.
Naomi_Adkins
  • August 20, 2025
THANK YOU - this WORKS!
Ariel11
  • January 30, 2026
First I've gotta give props to the plugin makers: Stray Component & Variable Finder is great, Variable Sherlock helped me out a lot too.
That being said, Figma approach to this bug is terrible. The problem is not a lack of file reviewing, its some sort of cache. I've deleted all pages of a given file and created a brand new empty one and there is still the Apply Variable Mode selector there.
Honestly, my company spends a lot in figma for this kind of lame simple bug to steal so much time from us.
Naomi_Adkins
  • February 5, 2026
Part of the issue is that Figma embeds Variable tokens at such a deep level sometimes (eg: a colour set as an underline on a component variant for hover state), and it doesn’t make it clear where you’re even pulling in the variables. Having a “select instances that use this variable value” type selector available directly from Figma is essential.
Figma: Why is this topic marked as solved, when it’s clearly not!
