How i can get access to global object figma in ui.tsx?
  • February 2, 2023
  • 1095 views
Iuri_Fazli
I need access to figma global object in ui.tsx file. How i can get it? In code.ts it’s work, but in ui.tsx no 😦
tank666
  • February 2, 2023
It’s impossible. If you want to access the global object from the UI, then you need to send a message from the UI to the plugin code, and then in the plugin code access the figma global object.
Please see the developer documentation for an example: Creating a User Interface | Plugin API
