How do these menu buttons function in appearance
  • March 23, 2025
  • 4 replies
  • 104 views
stefan cargoski
Hello Figma Community.
I’m fairly new with Figma, and also with web interaction concepts, because I’m coming from the world of print design. I have a question related how this particular concept works with a 6 state button function. I’m confused why it’s set up the way it is, with the hover states being on 5 & 6, and not on states 3 & 4. One would think, the button by default is OFF, and when the mouse hovers over the button it would HOVER, then when pressed it would make some change of colour (button Background or text colour Change).
I have been assigned a task in my group, and this is the layout of the buttons, Can someone please explain how this works, and what would be a good example, by making a mock up I could possibly follow the layout.
Thank you.
Best answer by KennLucas
Who cares what the order is? That has nothing to do with function.
i would more concerned that whomever has given you the task is not very strong in this.
There are not “on and off” states. It is basically:
base = default
hovered = when hovering with cursor. Not relevant on mobile devices.
focused = when interacting with keyboard or voice
pressed = called "active” in HTML, is when clicked or held down
selected = might be if the item had a state to indicate it was the active item
disabled = self explanatory
but no matter the state, the order makes no difference in function and is not where you should be focusing.
not sure if you are being given this task as part of a work assignment or some class project. What is the “group” that you mentioned?
In either case, I would question the authority here.
Raphael_M
  • March 23, 2025
Hi, Stefan.
I think you need to understand first the user actions that would trigger the button's state.
On web, the button state would always start at default (unless it's disabled) then when cursor is on top of the button the on hover state would trigger then after that when you click it or press it that's when the pressed state would trigger. But on mobile since there is no cursor, the hover state would be skipped and only the pressed or onclick state would be triggered.
The pressed state would only trigger when you click the button, so it'll depends on which state would it be first before the user clicks the button. The most common visual design on pressed state is a ripple effect on the button.
  • WEB - on hover → pressed
  • MOBILE - default → pressed
But on web, there is another state which is on focus when the user is using a keyboard and not a cursor.
stefan cargoski
Thank you for your explanation Raphael.
I'm starting to get more familiar with the functions, and your information is helping me.
But why has the team member given me the buttons in that order: Default, Pressed, Hover rather than Default Hover, Pressed?
KennLucas
  • March 23, 2025
base = default
stefan cargoski
Thanks for your input Lucas.
As its common sense, to have the functions from Default/off to hover, then click to activate a button behaviour.
This is a group assignment, some B class type of media college. I'm only following what the instructor is telling the class.
What confused me is why the mouse functions can go back and forth and not in order. but you said it doesnt matter. So is up to the developer to make the button functions appear as he likes with code?
