How do I indent a line in Figma?
  • March 23, 2023
  • 7 replies
  • 14748 views
michalina_Trabinska
How do I indent a line in figma?
Best answer by tank666
Change the value of the Paragraph Indent property (№7 in the screenshot).
Figma Help Center
tank666
  • March 23, 2023
Figma Help Center
Jeremy_Chevallier
This feature appears to have been moved under Details now, however it doesn’t seem to allow negative values, which means I can’t put lines 2-n in a hanging indent like this:
Would like to see this use case supported.
  • September 22, 2023
Agreed! Hanging indent would be super useful!
Timothy_Moyer
Agreed. Not resolved. Although I found Indent, changing value doesn’t seem to have effect. Why burry this within submenu?
This functional upgrade should be paired with larger request to copy & paste from say, Word document and maintain indentation/paragraph styles.
I copy content from other tools all the time into Figma.
Timothy_Moyer
Correction: It appears Indent doesn’t work when Unordered List is active. My intention is to indent the ordered list item - create child item.
mikilili
  • February 24, 2024
Why can’t see the Paragraph indent option on my Type settings panel? Could anyone help please? Thank you!
Gayani_S
  • February 26, 2024
Hey @mikilili, thank you for reaching out!
You might not see the option because your text is not aligned to the left?
Paragraph indentation offsets the text in the first line to the right. You can only apply Paragraph indentation to text that uses Text-Align Left.
You can find more information in our Help Center article: Paragraph indent
Let me know if what solves your issue, if not can you please share a screenshot of what you’re seeing on your end?
