How Do I Distribute a Text File With My Plugin and Read From It?
Hi,
this is my first Node.js/Typescript/Javascript project and everything is going fine, but I am not managing to add a file data.txt to my plugin and read from it in code.ts (data.txt contains some vector path data strings line by line).
The issue is (using npm run build -- --watch as my watch script) that I cannot import or require anything, as that’s either an Unexpected token import`` or a ReferenceError: 'require' is not defined.
Installing webpack and using webpack --watch as my watch script has solved this issue, but still, fs.readFileSync is TypeError: not a function.
Some more research has given me the impression that I am not to read from a local file using a client side javascript-script (I am sure I did not express this correctly), but how am I to bundle some data with my Figma plugin?
While this surely is a pure Javascript-Question, all my research has led to nowhere since I have difficulties transferring the context of the solutions I come across to the Figma plugin context, which is why I am asking in this forum.
Thank you very much for your help!
