Ajaya_Bajracharya
How can I use the same component library across multiple projects, each with a different color scheme (future requirement: and font family)?
Need way to use same component library across projects with different color schemes
Description:
I’ve built a component library file in Figma that includes buttons, inputs, cards, labels, etc. This library will be used in multiple upcoming projects.
The goal is simple:
Use the same components from the shared library in all projects, but apply a different color scheme (branding) for each project — e.g.,
  • Project A → Red theme
  • Project B → Green theme
  • Project C → Blue theme
    ...and so on.
I built the entire component library using variables (for colors) and published it. However, when I add the library to another project file, the variables are not accessible or tweakable there.
Note: I’m not talking about variable modes, since I’ll have 10+ projects with completely different brand colors.
What I need:
A workflow that lets me:
  1. Use the same published components from the library in every project.
  2. Change their colors (branding) per project easily.
  3. Keep the link to the main library so future updates (like padding, structure, etc.) automatically apply.
What’s the right way to achieve this setup?
Gaurav Thapaliya
I think you can use multi-brand color system. Create a collection named brand colors and then create modes for example “Brand A (Red), Brand B (Blue)” and so on. After this you can alias it to the respective variables.
After this you can bring any component from asset library and change it colors to respective brand
