rahend
May 29, 2025 5:08 PM UTC
How Can I Prevent This Node Problem?
Hi figpals,
I'm creating an icon, and this issue has been bothering me lately. Right now, the only way to solve it is with a hack. I know there are ways to fix it, but I really need to avoid repeating this workaround in a loop. If there's a way to prevent me from having to do this hack over and over again, it would be a huge help.
So here's the case:
First, i create an icon (absolutely) like below:
What I want to ask is about focusing on a selected object. I’m using an inside stroke for icon weight, which makes it easier to control the size measurements and set the radius for each corner.
Then, to finalize, I need to vectorize the stroke using the “Outline Stroke” feature. And here’s what happens:
A line appeared at the bottom, and what’s even stranger is that it only shows there. But when I enter edit mode, it looks like this:
There is a visible line right there, so I tried to remove it as shown below:
But this is what I ended up with:
It removes the area right next to it, which keeps frustrating me—there’s no clear pattern. Not all icons behave like this.
What I need, first and foremost, is a way to prevent this issue altogether. I know there are small adjustments that can fix it, but honestly, that’s not an efficient solution for me.
Please help and let me know if there are other ways to avoid this. Thanks!
Nellya
NellyaSolution
Power Member
May 29, 2025 5:25 PM UTC
Hi. I’m not sure how to avoid it, but here is the quick way to fix it
Nellya
NellyaSolution
Power Member
rahend
rahendAuthor
May 29, 2025 7:11 PM UTC
Thanks, ​@Nellya. As I mentioned, this can be fixed in some ways (and your way of fixing it is just like what I’ve been doing lately). But let’s say I create a thousand icons, and hundreds of them have anomalies like this—it wouldn’t be efficient for me to fix each one manually.
What I still need to know is how to avoid this issue or, at the very least, understand why it happens in the first place. Let’s hope Figma can provide some answers.
