How can I check the changes made by someone in my design file?
  • August 18, 2024
  • 4 replies
  • 2283 views
Artaherzadeh
Hi
I want to see the changes made by someone, just the changes. Right now when I click that change in the history panel, I see everything and it’s really hard and impossible sometimes to track the changes.
  • August 20, 2024
Hi there,
Thanks for the post!
If you have access to Dev Mode, you can see the changes to the frame as this article explains:
Figma Learn - Help Center
Without Dev Mode, checking version histories is probably the closest alternative, unfortunately.
Thanks for your understanding.
Toku
Artaherzadeh
  • September 3, 2024
Dev mode is good for reviewing changes when you know what those changes are.
I have two designers working with me and some times the accidentally remove or edit something and I want to know which files have changed. My design contains hundreds of pages and it’s hard to track these changes so a feature is really required here to see the changes like VS Code plugins or GitHub features which makes the removed lines red and added lines green so you can easily monitor the changes. Version history to be honest is useless without this feature.
Eric48
  • October 29, 2024
I would like to have the Version History show the pages where the changes were made - currently, it stays on the page you are on where I have designers that work on different pages within a file, and this should jump me to the page and the frame the edits were made
  • October 29, 2024
Thanks for your feedback! I know version history is not perfect solution in this case. We will share this internally for future improvements!
Thanks again for your feedback.
Toku
