Horizontal Padding not being applied in autolayout
  • June 13, 2024
  • 5 replies
  • 759 views
Cory2
I’m taking a Figma class and in the video there are 2 things regarding ‘horizontal padding’ that are inconsistent with how my design is acting compared to the instructors.
  1. In the top left I can’t select the ‘Distribute horizontal spacing’
  2. When I add horizontal padding to a group of components, it shifts them to the right, while and doesn’t add the correct padding on the left and right side of the cards which should push them 24 pixels inside of the parent frame.
  • June 13, 2024
the layers inside need to be set to fill
Cory2
  • June 14, 2024
As in the individual components/cards that make up the card stack?
  • June 14, 2024
I guess so. Whatever is inside of the currently selected frame on your screenshot and all the layers further in the hierarchy.
Lorenzo Mecugni
Hi guys, what do you mean “layers inside need to be set to fill”?
same issue here .. vertical padding works just fine, horizontal padding instead pushes my text boxes to the right ..
help please, thank you
Rafa.lima
  • July 7, 2025
It’s not the fill. In your auto layout settings the width is set to “fixed”, you must switch to “hug” as the height.
