Holding ALT key when mouse drag does not duplicate selection in Chrome
  • August 27, 2024
  • 9 replies
  • 463 views
Dave_Chuang_Xuejin
I am using Chrome (flatpak) running on Fedora 40 Linux, but the usual ALT-mouse-drag on a selected layer does not duplicate. This was working when I was on MS Edge running on Fedora 38 Linux.
  • Figmate
  • August 28, 2024
Hi @Dave_Chuang_Xuejin, Thanks for reaching out about this.
I noticed in this tutorial, the shortcut is mentioned for MacOS and Windows but not for Linux:
  • Mac : While holding Option, click and drag
  • Windows: While holding Alt, click and drag
I don’t have access to a Linux machine, so I’ll check internally to see if we have any information about this.
If anyone from our community has additional insight on this, please feel free to share here.
Thanks once again for reaching out. Your input is much appreciated!
Dave_Chuang_Xuejin
Yup, I am aware of the shortcuts in Mac too. But I am not able to isolate if this problem is a browser issue, or general Linux issue, or Gnome (Desktop Environment for Linux) issue. But I did not had any issues on previous Gnome 44 on the same browser MS Edge.
Appreciate if someone in the community who has Linux can verify if problem exists too.
  • Figmate
  • August 29, 2024
Hi there, Thank you for your response.
Could you kindly confirm if your Linux OS supports the minimum browser requirements - Chrome 99 or later as shown here?
Thanks again for your help! We look forward to hearing from you soon.
Dave_Chuang_Xuejin
Hi, my Chrome and MS Edge are on version 128.
I have tested this on Firefox v129 on my Linux, and I am able to use the ALT-mouse-drag to copy a layer.
  • Figmate
  • September 3, 2024
Hi there, Thank you for the additional information.
I apologize if my previous request was unclear.
Based on the link provided in the previous post, the requirements for Linux and Chrome are as follows:
  • Minimum OS requirements for Linux: Any Linux OS that supports the browsers mentioned in the minimum browser requirements
  • Minimum browser requirements for Chrome: Chrome 99 or later
If you are experiencing an issue with a shortcut for duplicate in your Chrome browser running on Linux, could you please confirm if your Linux (Fedora 40) supports Chrome 128?
I tried searching for this information, but I couldn’t find relevant details. Could you please let us know if there is a link or any way to check the status of the support?
Once this is confirmed, I will relay this information to our relevant team.
Thank you once again for your assistance!
Dave_Chuang_Xuejin
Yes - Fedora 40 officially supports Chrome 128. But further checking online reveals some critical bugs with it, however not within my expertise and knowledge if the issues are related to this.
Since i have a workaround using FireFox, we can close this.
AndrewTerry
Would you mind sharing the workaround you found for Firefox?
I’m using Linux Mint 21.3, with the built-in Firefox (which shows as v131.0.3), and when I try to ALT+Drag to duplicate, the actual browser window gets dragged around.
Dave_Chuang_Xuejin
Hi I just tried again today on the Firefox and unfortunately it doesn’t work now.
I am using Firefox on flatpak 131.0.3 (64-bit) on Fedora 40, Gnome 46.
My current workaround is using CTRL-D to duplicate the layer or artboard.
Ativie_Oserefemhen
Not sure if this would help. I’m a Linux Mint user and for me ALT + drag moves the entrire window by default, which consequently eliminates the expected Figma duplicate functionality.
To stop this, I had to go to my system’s Windows setting, then in ther the Behaviour tab where I set Special key to move and resize windows to Disabled. That solved it for me.
