Привіт коли переглядаю прев’ю,показує лише 1 Frame а не цілу сторінку( Поможіть
Page 1 / 1
May be you have set the wrong frame as Flow Starting Point. You can either:
Set main frame as Flow starting point by selecting the frame and adding it to flow start in Prototype Panel. You’ll have to remove the current frame as flow starting point.
Select the frame with what you want preview to start and then click the preview button.
thanks, figured it out👍
If it worked, please do mark the answer as solution 🙂
