Having issues with state management
  • June 16, 2023
  • 259 views
1). I have made an input field component.
2+3). And I have also checked the reset state box on both fields
4). When I use the component instance on the actual frame it works as it should but it doesn’t return to its default/original state even when i touch other input fields etc.
5). And it also makes every other instance of the same input field component to work even if that instance is on next or other page/canvas.
The numbering with sentences are reference for the image (e.g. reference for 1st sentence is 1st picture etc). [p.s. the image numbering starts from top left]
Can someone help me out.
