Guys, a newbie need hep, how to tap X to close the scrolling sidebar menu ›
  • January 15, 2024
  • 192 views
Loc_Tran
Please search for existing topics before posting! Press 🔍 at the upper right to search.
I can not use the component sidebar to scroll
Haroll
  • Active Member
  • January 15, 2024
Hi @Loc_Tran
I can see from your screenshot that you connect the scrollbars of your component’s variant. What did you use? Have you try an on Drag interaction ?
Loc_Tran
  • January 15, 2024
can you tell me how to make it? I want to make a scrollable sidebar that users will tap X to return to the main screen. 😦
It can scroll without “X” but when overlaps with the “X”, it cannot scroll anymore
Haroll
  • Active Member
  • January 15, 2024
Click on one of your scrollbar interaction, then change the interaction type from On click/On tap to On drag (as shown below).
It should not be a problem with the cross icon since they don’t overlap
This solution will make the view scroll, but you will only be able to “scroll” into it by dragging the scrollbar.
