"Go to main component" doesn't focus correctly
Nico008
Hello,
Since a few days, when going to main component in library, it shows me the good page, but focus is not set on the selected component. Is it a bug? something mine?
Thanks in advance!
Best answer by Mathieu11
@Gayani_S Found another example, and your instructions solved the issue, thank you very much!
This was happening in the app. Using a browser I’m not normally using for Figma, the behaviour was different, as the Restore Component prompt appeared. Clearing the cache and restarting the app solved the issue, i.e., the Restore Component prompt appeared there too.
Dragihop
  • October 2, 2023
when I click on the button, it redirect me to the file where there is the particular librairy but it doesnt center the screen according the selected component, we have to find it by ourselves, can you guys fix this? thank you so much !
Philip15
  • October 3, 2023
I am having the same issue since a week or so.
Apolline
  • Active Member
  • 40 replies
  • October 3, 2023
Same issue here, and it seems like links to selection are also having the same issue
dvaliao
  • 4664 replies
  • October 3, 2023
Hey @Dragihop, thanks for flagging this!
We’ve merged your topic with another one tracking the same bug. We can see that you’ve also reached out to our support team directly on ticket #820090. Can you please reply to their most recent message?
Be sure to share a full screen recording, if possible, include a link to the file, and share it with support-share@figma.com so they can take a closer look.
Zofia_Zajaczkowska-Tomaszewska
I was wondering the same thing! Would be great to hear from someone @ Figma
(btw it still works okay in dev mode panel)
+1 I have same issue since yesterday
Daniel137
I’ve also been having this issue for the last week
Also have this issue. The zoom is not focussing on the component.
dvaliao
  • 4664 replies
  • October 5, 2023
Hi Daniel, sorry to hear you’re also having this issue!
You can submit a bug report to our support team directly via the form here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Be sure to use your Figma account email, include a screen recording/link to the file, and share it with support-share@figma.com so they can take a closer look.
Ryan_52
  • Technical Quality Specialist
  • 382 replies
  • October 6, 2023
Hi everyone, thanks for raising this. Are you seeing this issue in the desktop application or in the browser? Mind sharing a short video?
Yulin_H
  • October 6, 2023
This issue is also happened to my desktop application.
Yulin_H
  • October 6, 2023
FYI, it can focus on the right main component, but lost the location auto track.
Nico008
  • 4 replies
  • October 6, 2023
Hello Ryan,
In my case, it’s also in desktop app, and as Jennifer_Lyle and Yulin_H said, focus is working, but zoom on component is not. (sorry i wasn’t precise in my original message)
Video 1: In this case, instance and main component are in different files (library is linked in the instance file) and it fails.
Video 2: the instance is in the library itself and it works
Hope it can help. Thanks!
Timmy1
  • October 6, 2023
yep… also getting this. its REALLY annoying!! it takes me to the page but doesn’t take me to the actual component so I have to zoom in and find it. 😦
ysjcapelle
  • October 9, 2023
Same here! Post says it’s solved, but it’s not solved at all. I already submitted the form just a few moments ago, including the screen recording.
Ben_Smeets
  • Active Member
  • 38 replies
  • October 9, 2023
It’s a bug, happened after the update of a couple of weeks back. Figured it would be obvious and figure itself out, but it seems to still be there.
dvaliao
  • 4664 replies
  • October 9, 2023
Hey there, thank you for contacting support directly, and sorry for the confusion!
The marked solution is specifically for the first user. Support is still waiting for their reply with the requested info. To be transparent, support isn’t able to flag this as a specific bug until they can consistently reproduce the issue, so they can work on the fix.
  • 8 replies
  • October 10, 2023
I have the same issue, hope this gets fixed sooner than later! 👌t2:
OnlyRodas
  • 9 replies
  • October 10, 2023
Same boat, buddy! Hoping they’ll squash that bug real quick. I’m stuck trying to hop over to the main component in another file and can’t swap it out for one in the current file. Fingers crossed for a fix soon!
Carey_Smith
  • 10 replies
  • October 11, 2023
Also seeing this issue on Desktop (mac). If ‘Go to main component’ still selects the right layer for you, pressing 2 will focus to the current selection (which is the workaround I’m using for now)
I think this is because although it is the same library, the parent components are not in the file you are working on (so yeah its a bug).
It seems as though when you are working in the same file where the parent components were created and you click on “Go to main component”, it goes directly to the correct component, however if you are working on a different but the same library of components file it just goes to the correct page where the component is, but not highlighting it!
Nico008
  • 4 replies
  • October 12, 2023
Thanks for the tip Carey!
  • October 12, 2023
Hi!
Sorry for delate, i’m busy-busy…
I’m sorry but it seems to work sometimes, and others no :/.
It’s curious…
I’Il try to give your more detailed information if it can help.
Thanks!
Nicolas Didelot
UX-UI Designer
Nicolas Didelot
+33 (0)7 52 06 48 78
nico@nicolasdidelot.com
www.nicolasdidelot.com
Ryan_52
  • 382 replies
  • October 12, 2023
Hi everyone, thank you for your reports. We are pleased to inform you that a fix has been successfully released!
Please refresh Figma to ensure that you are using the fixed version.
Marek_Martancik
Are you sure? I have this issue months, and stille doesn’t work at all, for me and for my colleagues.
