Hosam_Elshazly
May 2, 2024 4:00 AM UTC
getVariableCollectionByIdAsync returns error
I need help guys to figure out how to get variable collections from a published library.
I have created a few variables in a library file, and created a plugin to fetch these variable collections using a plugin in a different Figma file.
So, first I am getting variable collections & variables using REST API
Next, by iterating on the variable collections object here comes the problem
I keep getting error ““MemPool/Node: cannot dereference nullptr” in countError (FGMemPool.cpp)”
Keep in mind I used both id & subscribed_id but still doesn’t work
Any ideas about this error?
Wes_Barichak
Oct 1, 2024 1:08 AM UTC
@Hosam_Elshazly Did you ever figure this one out? I’m stuck on this same error, not really sure what I could be doing wrong.
Power Member
Oct 8, 2024 11:48 AM UTC
Try using this: figma.teamLibrary | Plugin API first, then check if variable collection exists via key. This error might be happening because the library variable collection is not enabled in the file. Just a theory.
