Frame resizing and keeping frames in same relative spot
  • January 7, 2023
  • 1140 views
Jeffrey_Tunkey
Hi all, does anyone know of a way to create the element shown below so that as the amount of text increases and the frame height increases, the heart would stay in the same relative spot straddling the bottom of the frame? I’m stumped, thanks!
tank666
  • January 7, 2023
Your object should be a frame with auto layout, and for an element with a “heart” icon, you need to apply an absolute position and set right and bottom constraints.
This reference material should be helpful to you:
Figma Help Center
Saulo_Vallory
  • Active Member
  • January 7, 2023
All you need to do is select “right” and “bottom” constraints for that element in relation to the parent frame as shown in the image below:
