heicodersacademy
FILE_UPDATED webhook doesn't trigger on file edits (but FILE_COMMENTED works)
I've been setting up a webhook integration to monitor file changes, and I ran into some confusing behavior with the FILE_UPDATED event. I'm sharing my findings here in case it helps someone else, and to confirm if this is the intended behavior.
My Setup:
  • Plan: Professional Plan
  • Authentication: Personal Access Token
  • Scopes: My token has webhooks:write, file_content:read, and file_comments:read permissions.
  • Integration Tool: I'm using n8n (a workflow automation tool) which receives the webhook events. My n8n instance has a public URL and is reachable by Figma.
  • Webhook Event: FILE_UPDATED
The Problem:
When I selected the FILE_UPDATED event, I expected it to trigger when I made changes to a design file (e.g., moving an object, adding a shape, changing a color). However, no event was captured by my webhook endpoint while I was actively editing the file.
What I Tested:
  • FILE_COMMENTED works perfectly: If I switched the event type to FILE_COMMENTED and added a comment to the same file, the webhook fired instantly and my workflow received the data. This confirmed that my basic setup (token, scopes, webhook URL) was correct.
  • FILE_UPDATED doesn't work on edit, only work delete file: When I switched back to FILE_UPDATED, making edits did nothing in real-time.
Hope this helps someone else save some time!
Hei
Anastasia Zaikovskaya
Hello! The docs says that the event will be triggered within 30 mins. Wasn’t that the case?
FILE_UPDATE
Triggers within 30 minutes of editing inactivity in a file
Sarunas K
Having similar problems. The webhooks seem to be completely broken. Days of not receiving anything, multiple pings for new webhooks. Firing wrong webhook for event.
There seems to be no fix for 3 years. At least a workaround? Make events API - to pull file activity, something…
