FigJam thumbnails doesn't fit the frame
  • June 14, 2024
  • 14 replies
  • 798 views
Samir_PRODATA
After the new update my thumbnails became smaller for FigJam files. Do you have any idea about this bug or smth?
Best answer by djv
Hey All, thanks for following up!
I just tested setting a 1920 x 1080 (16:9) thumbnail in FigJam file, and it is working as expected on my end. Be sure to check that you’re using the correct dimensions and that your thumbnail is wrapped in a Section or a Frame, if you’re copy/pasting the thumbnail from Figma.
By default, Figma uses an overview of the entire FigJam board to create a file's cover.
You can use a section as the thumbnail image for the file or a custom template.
  1. Select the section you wish to use as the thumbnail.
  2. Click Set as thumbnail.
You can also create custom thumbnails in Figma Design files to use them for FigJam file covers.
  1. Create a frame to use as a custom thumbnail.
  2. Copy/paste the frame to your FigJam file.
  3. Right-click on the frame in the FigJam board.
  4. Select Set as thumbnail from the options.
  • June 17, 2024
Hey @Samir_PRODATA, thanks for flagging this!
We’ll pass this onto our team to investigate.
Fruzsina_Ferenci
Hey everyone!
I’ve noticed that the cover thumbnails in FigJam and Figma, even with the same 16:9 ratio, are now displayed/cut differently compared to before. Has anyone else experienced this issue? Any solutions or workarounds? Thanks for your help!
  • June 19, 2024
Hey @Samir_PRODATA, thanks again for flagging!
Our team pushed a fix for this. Please refresh and let us know if you run into any further issues.
Samir_PRODATA
  • June 20, 2024
It is fixed now. Thanks for your consideration ❤️
  • June 20, 2024
You’re welcome, @Samir_PRODATA!
So happy to hear that it’s fixed on your end!
Ana_Tenreiro
Hi! Me and me colleagues are experiencing the same issue. I think it occured with the new UI. Do you know how it can be fixed? Thanks!
  • October 8, 2024
Hi @Ana_Tenreiro, sorry for the trouble!
It’s likely that you need to update your FigJam thumbnails. We recently updated the aspect ratio to 1920 x 1080 (16:9) for all file types across the file browser and Community.
x.com
lauren.macurak
Hi @dvaliao it seems, even with the new dimensions, the thumbnails still do not properly fit for FigJam files.
  • October 17, 2024
Hey @lauren.macurak, sorry to hear this!
Did you update your FigJam thumbnails to 1920 x 1080 (16:9)?
The original topic was a bug back in June, where thumbnails had different sizes depending on the file type. This cause FigJam thumbnails to appear differently in the file browser.
With the recent change on October 3rd, everyone must update their thumbnails to 1920 x 1080 (16:9), since all file types must be updated to these dimensions to appear correctly in the file browser.
lauren.macurak
Yes even with the new dimensions (1920x1080) fig jam files still aren’t fitting
  • October 17, 2024
Thanks for confirming, @lauren.macurak!
Are you able to provide a screenshot of how the thumbnail appears in your file browser as well as a URL link to your FigJam file, so our team can take a closer look?
If so, please include a link to the file in this topic thread, and share edit access with support-share@figma.com.
Carina Oswald
Hey ​@dvaliao,
came here because of the same issue.
In my screenshot you can see that there are still pixels not covered, even with a 16:9 ratio:
tony-coccaro
  • April 23, 2025
Guys, this issue is far from being solved. As you can see from my attachment, the image has been properly set as thumbnail (16:9 ratio, 1600*960px) in Figjam, but it does not fit the cover. Am I doing som’ wrong or you need more investigating this matter? Thx
  • May 12, 2025
