Export multiple frames to file system with exportAsync()
  • February 1, 2022
  • 5 replies
  • 1963 views
Genoni Studio
I understand how to use exportAsync() to create a Uint8Array that I can send back to ui.html to trigger a single download.
Does someone have an example of exporting multiple frames? The behavior would be the same as exporting multiple frames within the Figma app.
Erwin_Goossen
I’m currently working on a plugin for exporting a whole bunch of images once. I use jsZip for creating a zip file with all the images in there in the correct file structure. This way you end up with 1 single file you could trigger to download
Nidhin_Kuttikkattu_Rajeevan
Is there any example on this thread please?
Zaydek
  • February 1, 2024
It’s pretty straight forward with JSZip. It only has a few APIs and then you need to call a <a href download> on the result blob. This should help you get started. ChatGPT.
Luis_Abaladas
Hey @Zaydek !
Sorry for the bump on this old topic — but is there any way you could provide that link again, it’s currently broken, and it might have the solution for my problem 😀
Zaydek
  • March 21, 2024
@Luis_Abaladas Sorry for the dead link but yeah the process is more or less the following. You call exportAsync multiple times, building up some kind of data structure like an array, then you simply send the to the UI thread (you don’t have to preprocess it in the Figma thread). Once it’s in the UI thread, you can base64 or download it as a blob using JSZip.
Feel free to DM me on Twitter or Discord if you need, can find me here https://twitter.com/username_ZAYDEK.
