Embed-code from figma prototype is not valid for behance
  • September 13, 2024
  • 5 replies
  • 286 views
Francesca_Schulz
Hi, I have found similar entries about the topic but I still did not figure out what the problem is.
I want to upload a Figma project on behance and integrate a Figma prototype. But it is always saying the my embed code is not valid. I went to my Figma prototype and clicked on share. There I set it on visible for everyone and clicked on the embed code. I copied it and went on behance. There I started a new project and clicked on the prototype button where I pasted the embed link. It is an iframe link. But it is always saying that the code is invalid. Does anyone know what the problem still could be?
This is the link to my project: https://www.figma.com/proto/m4igkFLXpCBhLn55sfvYXi/CAPSTONE_group5_figma_francesca_final?node-id=1240-10150&starting-point-node-id=1240%3A10150&t=jQsewidCut1fLUDZ-1
And that is how the embed code looks like:
Thanks in advance for your help 😉
tank666
  • September 14, 2024
The embed code is actually correct. You need to contact Adobe support team to fix/update/add support for embed.figma.com domain.
As a quick fix, you can edit the src attribute value, replacing the embed subdomain with www.
Apoorvi_Vishnoi
I am facing the same issue after the recent Figma update. Additionally, I’m unable to post the recorded video of my prototype on Behance; it keeps loading endlessly …
This is frustrating !!!
st_ef
  • November 25, 2024
That worked thank you so much!
Dishant Mann
  • January 28, 2025
hi, can you please help, my embed code is also not working when i upload it to behance through the prototype section. Here is the link- https://www.figma.com/proto/MeMu0y858Qob1hsSCm82bT/Untitled?page-id=0%3A1&node-id=1-2&viewport=306%2C321%2C0.37&t=q9M5OD7ryMDhAv0L-1&scaling=min-zoom&content-scaling=fixed
tank666
  • January 28, 2025
@Dishant Mann, I just checked and the prototype embed into the Behance project worked without any errors. Behance now seems to support the embed.figma.com domain, so the Figma prototype embed code doesn't need to be modified.
