Dynamically create palette with createPaintStyle - locked on hexToRGBA() JavaScipt function
  • July 2, 2021
  • 8 replies
  • 1997 views
flexbox
Hey!
I am playing with scripter and the Figma API to automate color generation
Let’s say I have this palette
const palette = {
	'blue-50': '#EFF6FF',
	'blue-100': '#DBEAFE',
	'blue-200': '#BFDBFE',
	'blue-300': '#93C5FD',
	'blue-400': '#60A5FA',
	'blue-500': '#3B82F6',
	'blue-600': '#2563EB',
	'blue-700': '#1D4ED8',
	'blue-800': '#1E40AF',
	'blue-900': '#1E3A8A',
I am able to loop thought the values with
function createPalette(){
  Object.keys(palette).map(key => {
    print(key)
    print(palette[key])
    createFigmaStyle(key, palette[key])
But I have a problem with my function to dynamically create Figma Styles
function createFigmaStyle(colorName: string, hexValue: Paint){
  const style = figma.createPaintStyle()
  style.name = colorName
  //here I have an error
  //Type 'string' is not assignable to type 'RGB'.
  const colorRGB: RGB = hexToRGBA(hexValue, 1)
  // style.type = "PAINT"
  const paint: SolidPaint = {
      type: "SOLID",
      color: colorRGB
  style.paints = paint
My question is Do Figma have an official way to convert hexa value to RGB?
because my function hexToRGBA is a random copy paste from Stackoverflow 😅
Best answer by flexbox
🎉 Works like a charm
2021-07-02 14.41.39
Here is my function
function hexToRGB(hex: string) {
  const r = (parseInt(hex.slice(1, 3), 16) / 255);
  const g = (parseInt(hex.slice(3, 5), 16) / 255);
  const b = (parseInt(hex.slice(5, 7), 16) / 255);
  const result = {
    r: r,
    g: g,
    b: b
  return result;
  • July 2, 2021
There is no “official” way. Does the function you copied not work correctly? Note that Figma stores colors (RGBA) in a fractional format [0-1], but the code you copied likely uses [0-255] integer values, so to make it work correctly you will need to divide the numbers you get by 256 (except for alpha, which is likely already in [0-1] range.
flexbox
  • July 2, 2021
Here is an output of scripter
flexbox
  • July 2, 2021
I see, thank you for the input ❤️
flexbox
  • July 2, 2021
2021-07-02 14.41.39
Here is my function
  const result = {
    r: r,
    g: g,
    b: b
  return result;
111749
  • January 8, 2022
The toSolidPaint method should work 🙂
Rishab_Sain
Great, thanks for sharing.
Kevin_van_Breemaat
For anyone looking for this after me. It’s still solid info but, Figma (now) requires paints to be in an array it as simple as this:
Turn the last line:
Into:
style.paints = [paint]
tank666
  • July 3, 2023
It has always been. Paints must be an array of objects.
