Hi Everyone,
I am new to Figma, I am trying to make a plugin that can copy the components from the team-published components to another team’s project.
I have published a few test components in team projects and was able to access the team components list and individual components from Figma API
Now the challenge is how I can create an instance of that component and append it to my current Figma page
Below is the function that can describe my use case
const getComponentDataFromComponentKey = async () => {
const personalAccessToken = ' ' PERSONAL ACCESS TOKEN ]';
const componentKey = ' ' COMPONENT KEY ] ';
const headers = {
'X-Figma-Token': personalAccessToken,
const componentSet = await fetch(`https://api.figma.com/v1/components/${componentKey}`, {
method: 'GET',
headers: headers,
const componentData = await componentSet.json();
console.log(componentData?.meta);
//Below is something I want to achieve
const componentSetNode = await figma.importComponentByKeyAsync(componentKey);
const instance = componentSetNode.createInstance();
instance.x += 100;
instance.y += 100;
figma.currentPage.appendChild(instance);
importComponentByKeyAsync is giving me error 403 error and from componentData?.meta I can’t create the component instance.
Is there any way to do this?
Would be really helpful for your valuable input .
Thanks 🙂
Could you clarify which key you are specifying: ComponentNode.key or ComponentSetNode.key?
Sure I am not sure the nature of the key but i am taking the below key from the object , i thing its componentNode.key
“key”: “d2c8f0c089641d97834a3536830a2cc1badc4183”,
"error": false,
"status": 200,
"meta": {
"key": "d2c8f0c089641d97834a3536830a2cc1badc4183",
"file_key": "eQ7H4hvYqOBg6uwqRPX5pA",
"node_id": "23:63",
"thumbnail_url": "",
"name": "Landing Page",
"description": "",
"description_rt": "",
"created_at": "2023-11-10T17:12:19.214Z",
"updated_at": "2023-11-10T17:12:19.214Z",
"containing_frame": {
"name": null,
"nodeId": null,
"pageId": "0:1",
"pageName": "Page 1",
"backgroundColor": null,
"containingStateGroup": null
"user": {
"id": "1280533109927091343",
"handle": "Adarsh Kumar Singh",
"img_url": ""
"i18n": null
I am using the below API for access the Object https://api.figma.com/v1/components/d2c8f0c089641d97834a3536830a2cc1badc418
Well, a 403 error code means that you do not have access to the file where this component is located.
