Developer cannot measure this tag widget
  • June 16, 2024
  • 187 views
Hi there, I have a problem with widget. After import a tag widget in a frame, I cannot measure this tag widget. I tried to share this project to my team project, but developer send a feedback to my that he cannot measure inside the tag widget.
My question is what can I do ?
Best answer by y_toku
Hi there,
Thanks for the post. Just to confirm, it looks like you’re using this Widget: https://www.figma.com/community/widget/1266973941595337440/tags
It seems there’s only a single layer, which is why you can’t measure anything. You can measure between layers, but since this widget only has one, it’s not possible. This widget works for both FigJam and Figma, but it seems to be optimized for FigJam based on the description.
Unfortunately, there’s no workaround to measure within this widget.
Thank you for your understanding.
Toku
  • June 18, 2024
Hi there,
Toku
  • June 22, 2024
Thanks a lot
