Dev mode doesn't show tokens according to semantics
  • June 27, 2024
  • 381 views
Ana_Carolina_Lima
hey guys! I’d like some help solving a question about tokens in Figma and handoff to devs.
On design view, we have the token applied with the semantics we created in the global tokens.
But, on dev mode, these semantics don’t appear, only the token values appear, for example: “12px”, for the font size which we call “small” and “400” for the weight which is the default, “regular”.
Do you know if there’s a plugin or some way to make dev mode show the tokens just like their semantics?
Ana_Carolina_Lima
An update that happened after this publication: I found the TokenStudio plugin and from the tests carried out, it seems that it will help solve the problem.
Emma_Utsi
  • January 16, 2025
Hi ​@Ana_Carolina_Lima
Are you able to help me with the same issue?
I need to find a way to add a semantic tag to my components that can be seen in the code from dev mode.
