Decimal Values in Sizes, Detached Fonts, and Inability to Save Changes
  • March 5, 2025
  • 18 views
Arina Bashkirova
  1. At a certain point (approximately 6 hours ago), a frame containing master components suddenly malfunctioned:
    • Element sizes changed to fractional values (e.g., 24.56px instead of 24px).
    • Fonts from the library stopped applying correctly.
    • I’m unable to adjust sizes in the master component, even though Constraints and Auto Layout have been checked.
  2. The issue only occurred in one frame; other elements in the file are working fine.
  3. I cannot revert to a previous version of the file because many new elements have been created in the last 6 hours.
What I’ve already tried:
  • Checked and reset the frame scale to 100%.
  • Verified Constraints and Auto Layout in the master component.
  • Reconnected the font library and created new text styles.
  • Used plugins like Round to fix fractional values.
  • March 10, 2025
Hi there,
Thanks for reaching out. It seems unusual that the size changed so abruptly. I've run some tests but haven't been able to reproduce the behavior.
Do you know if there’s anything unique about this frame? Since it appears to be the only one affected, it might have some differences from the others. If you can share the video recording including layer panel, that might be helpful too!
Toku
