ANDILE LUTHULI
Dark Aura APK Panel FF UI Overlay Component & Interaction Logic Question
https://dark-aura-apk-panel-ff.s3.ap-south-1.amazonaws.com/index.html
I am currently analyzing the mobile interface structure from the web export above and trying to replicate the specific "Dark Aura" glow effect within Figma for a prototype I'm working on.
Project Information
  • Name: Dark Aura Panel Project
  • Category: Mobile UI / Floating Panel
  • Figma Version: Latest Stable
  • Status: Prototyping Phase
  • Device Frame: Android Large / iOS
Description
I am attempting to recreate the overlay panel mechanics seen in the link. The "Dark Aura" visual style uses a specific drop-shadow and blur radius that I find difficult to export cleanly from Figma to CSS. When I view the panel on the live preview, the transition is smooth, but my Figma prototype lags when the panel toggles on/off.
Key Features (Design Specs)
  • Floating Panel Logic: The menu floats over the main content without clipping.
  • Dark Mode Optimization: High contrast text on dark, semi-transparent backgrounds.
  • Custom Toggle: The "FF" (Floating Frame) trigger button has a specific active state.
  • Responsive Layout: The panel adjusts height based on content density.
  • Smooth Animations: 60fps easing on the slide-in/slide-out transition.
Issue / Discussion
Has anyone else encountered issues when prototyping these specific "panel" overlays? Specifically, look at the way the header renders in the link provided. I need to know if this requires a specific plugin or if it can be done with standard Auto Layout and Effects.
Any feedback on the layer structure or component properties would be appreciated.
