CORS error for figma image
  • April 19, 2024
  • 7 replies
  • 1344 views
I keep getting this error when trying to GET a Figma frame image.
Access to image at ‘https://figma-alpha-api.s3.us-west-2.amazonaws.com/images/[xxxxxxxx]’ from origin ‘[origin]’ has been blocked by CORS policy: No ‘Access-Control-Allow-Origin’ header is present on the requested resource.
why do i get this when i try to get the image resource from Figma? if i implicitly it from an it works fine… My origin is listed in My App, my crossOrigin is set correctly…
  • April 19, 2024
You need to proxy it
  • April 19, 2024
only issue is that’s gotta have privacy implications for my users Figma stuff right? Are there proxy options that offer privacy?
  • April 20, 2024
You can proxy through your own server: download an image on the server and send it to the client.
  • April 20, 2024
Ah ok, yeah am gonna do that, but annoying as I then have to use up storage for a user’s Figma frames though.
  • April 20, 2024
You don’t have to save them. Check out some guides for image proxy for your backend language of choice. Usually you just receive the request as a data stream and translate this stream right to the client.
Eli_Berger
Had the same issue solved it thru this article Building Interactive Figma Widgets | CSS-Tricks - CSS-Tricks
If you are using NextJS, check out the link:
nextjs.org
