Convert/import Invision files to Figma?
  • January 11, 2024
  • 14 replies
  • 4189 views
Hanna_Gulbrandsen
I haven’t used Invision in a while. When I recently wanted to check out some old projects (~2019) for my portfolio, I realized that all my prototypes in the Studio App was gone. Customer support informed me that the app was fully deactiated and removed back in jan 2023.
I have the .studio source files on a harddrive. Is there any was to convert/import these projects and open them in Figma (or Adobe XD/any other software)??
I would so so so appreciate any tips and help! It would really suck if all my projects are gone for good…
Thank you!!
  • Figmate
  • 2624 replies
  • January 12, 2024
Hi Hanna, Thank you for getting in touch! I completely understand your situation.
While I wish I could offer more assistance, please note that .studio files are not directly supported for import into Figma. You can refer to the list of supported file types here: Import files into Figma
I’ve also looked into potential plugins that might address this, but haven’t come across any so far. Let’s keep an eye out for any insights or solutions that others in the community might have!
Thank you,
mohammed_mayat
got same issue
Hanna_Gulbrandsen
Thank you for checking, I really hope someone figures out a solution!
what is the best way to convert invsion into Figma design including layers ?
i tried to create sketch file in invision but Figma load it as gray squares…
help please 🙂
Thanks
AnRy
  • March 13, 2024
@Hanna_Gulbrandsen Hanna_Gu Hi. Have you found any solution? We have the same issue and can’t convert our .studio prototype file in any other format…
  • March 14, 2024
Sadly, no… 😦
Avi_Kumar
  • 4 replies
  • June 24, 2024
Hi, I am a software developer and am actually currently in the process of writing a program to convert the .studio files into a more adaptable img format (such as png). If you are interested, please let me know!
Hanna_Gulbrandsen
Hi, yeah I’m interested! Would be so good to figure out a solution to this problem.
Avi_Kumar
  • 4 replies
  • June 25, 2024
Wonderful! How can we get in touch? I would give you my email address if there were a way to private message, but I am tentative about posting it here on a public forum.
Jayme_Cox
  • October 3, 2024
Yes please! This would be incredible!
Avi_Kumar
  • 4 replies
  • November 25, 2024
Hi, thanks for your response! I have deployed the application I mentioned and it is live at https://studio-keys.onrender.com/ . Simply upload your Invision .studio files, and the app will return a zip with SVG renderings of the prototypes. I believe that Figma allows SVG imports, but if not, you can always use a free online SVG-to-PNG converter because I’m pretty sure they allow PNG. I hope this helps!
Avi_Kumar
  • 4 replies
  • November 25, 2024
Hi, I’ve deployed the application I mentioned and it is live at https://studio-keys.onrender.com/ . Simply upload your Invision .studio files, and the app will return a zip with SVG renderings of the prototypes. I believe that Figma allows SVG imports, but if not, you can always use a free online SVG-to-PNG converter because I’m pretty sure they allow PNG. I hope this helps!
KevKev
  • February 25, 2025
Your Program is sadly not working for me. Its an .studio file and uses only 13 MB of storage. Maybe you could fix your program please, cause i didn´t find any other solution to get my .studio-file into figma.
If im trying to convert it says:
Internal Server Error
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
tal.engel_extern
@Avi_Kumar I got the same error. Is that still active?
