Deniz Boomsma
Connecting Figma MCP Server with Google Antigravity
Hi all,
Is there anyone able to connect Figma MCP Server with Google Antigravity (I know it is not supported tool yet)?
I tried using client ID and secret, but I am receiving the following error:
Invalid scope: mcp:connect
Thanks a lot for comments!
aaronjellis
aaronjellisSolution
I was able to get it working via the latest Antigravity…
Just had to go into the editor, then hit these 3 dots and select MCP servers. It will ask you to install the Figma MCP config, then you should be able to run it just fine without much additional config. (easier than configuring claude code 😅).
McLovin217
Yes I’d like to know if or when will this be possible, I would pay for figma in order to connect it to google anti gravity
aaronjellis
aaronjellisSolution
Kirby Yardley
As always, ​@aaronjellis is helping us all succeed. 👋 What a small world moment.
I did have to go through “Manage MCP Servers” > “Configure” > “Uninstall”
Then I reinstalled the MCP Server to get it working.
aaronjellis
lolol
Happy to see your face here ​@Kirby Yardley!
If anyone has better guidance on how to get it to actually work well I’m all ears. Seems as though it pulls odd frames out of the file and struggles to really stay focused or get all the details. Figma Make is so good at adhering to the design, but I’ve yet to get Figma MCP to really stick to my screens. I have found a bit more luck using Dev Mode annotations while designing and telling the MCP server to pay attention to those.
andiihei
Every AI is stumped by this problem. 😅
Anyone know how do I fix this?
Deniz Boomsma
Thanks a lot ​@aaronjellis for your response ✌🏼 I was trying to work with Remote MCP server. I see that your way is for Local (Desktop) MCP server which is also fine. I hope soon we can also use the Remote server.
But so far it works!
VickyChing
hope for remote version sooooooon     TAT
Toluwalope Opaleye
same here, tried uninstalling and installing but it’s pointless
Toluwalope Opaleye
I did somehow find a way to overcome this. first check if you have node.js installed. try uninstalling the figma mcp on your antigravity and disable the mcp server in figma. close both applications and try installing the mcp server in antigravity it would most likely fail after that enable the mcp server in figma and refresh the mcp in antigravity. it should work
Caleb Ajuruchi
Hi Guys, I just asked the agent to fix this 👀 but it seems Node.js version was the issue.
