Vadim_D
Feb 17, 2025 3:39 PM UTC
Components wrapped in a Selection frame are not being copied correctly.
When copying (Ctrl+A, Ctrl+C) components that are wrapped in a Selection frame from one file to another, the variable settings and the arrangement of the components inside the inserted Selection frame get reset. Has anyone else encountered this? It used to work fine before, but after the update, it broke. I tried to illustrate this with screenshots.
Original
Paste
    Feb 18, 2025 8:20 AM UTC
    ​Hi ​@Vadim_D , Thanks for letting us know about this!
    I've been able to reproduce the issue on my end. Our product team is already aware of this issue and is actively working on. I've added your post
    to make sure it gets the attention it needs.
    We can't promise a super-fast fix, but we really appreciate you bringing this to our attention!
    In the meantime, you could try using below to duplicate, that seems to be working okay as a workaround.
    • Mac: ⌘ Command D
    • Windows: Control D
    Thanks again for your help!​
    Vadim_D
    Vadim_DAuthor
    Feb 18, 2025 10:16 AM UTC
    Ctrl+D is copying within one file, between files you have to use Ctrl+C - Ctrl-V (Windows), and this leads to loss of structure.
    For now you have to ungroup "Section" before copying between files.
    Thanks for paying attention, I hope this will be fixed in the next updates.
    Vadim_D
    Vadim_DAuthor
    Feb 26, 2025 10:10 AM UTC
    After the last update, something was fixed, but not completely. When copying components between files inside Section, the components began to copy correctly, but the component configuration is still not copied, when copying they lose the connection.
