Components don't update
  • August 30, 2024
  • 229 views
Assaf_Cohen1
I’ve got a library file that I’m pulling components from for the rest of my design files.
Recently when I update components on that file and publish the library, the instances on the other files don’t update.
Moreover, when I copy & paste the new version of the components into the design files, Figma suggest to update them to the old version of the component 😵
What’s happening?
  • September 2, 2024
Hi there,
Thanks for reaching out. It sounds strange. Can you try below?
Repair component connections
  1. Select a problem instance in a page
  2. The top left Figma icon > Quick Actions > Repair component connections
If the above does not not work, please try Regenerate all instances (slow)
  2. The top left Figma icon > Quick Actions > Regenerate all instances (slow)
If the issue persists, could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it.
Toku
