LinAmd
Jan 8, 2026 10:00 AM UTC
Components and autolayout/ scale state not visible when component is set to Fill width
Hi everyone,
I’m running into an issue with Auto Layout and component variants and I’m not sure what the correct approach is.
I have a button component with two variants:
- Default
- Hold / While pressing, where the button slightly scales up (as a press feedback)
When the component is used on its own, the scale difference between Default and Hold works as expected.
However, when I place the button inside a mobile screen frame with Auto Layout, I need to set the button to Width = Fill container to make it responsive. The problem is: in this case, when I switch to the Hold variant, the scale effect is no longer visible: Default and Hold look identical, because Auto Layout keeps the width constrained to the parent.
So my questions are:
  • Is this a known limitation of Auto Layout with scaling variants?
  • Is there a recommended way to represent a Hold state that involves scaling when the component must use Fill?
  • From a handoff perspective, should this kind of interaction be documented rather than visually simulated in Auto Layout?
Any best practice or workaround would be appreciated. Thanks!
