Change font family all text style in a library file
  • November 17, 2022
  • 5 replies
  • 3654 views
rahendz
Hi Figma, is there any way to change the font family of all text styles easily in a library file without changing them one by one?
Pavel_Kiselev
  • November 17, 2022
Get yourself Styler plugin. Then create an empty page and run Styler > Extract Styles. It will output all your text styles into separate text layers. After that you would need to run Styler > Detach styles to get them raw. At this stage you can adjust all of them in bulk like regular text. When you are happy with the result, select all and run Styler > Generate Styles.
It would match a layer name with a corresponding style name and update them with text properties on that layer. Real lifesaver it is )
rahendz
  • January 5, 2023
thanks for the reply, I’ll try it asap
Thank you this saved me a lot of time <3
Grayson_Rosato
Truly thank you from the future. Just saved me so much time settting up a new library for a new company.
Ken_Ottmann
  • December 14, 2023
Thanks a lot!! Big timesaver and unbelievable this can’t be done within the native functionallity…
