Center Align Hanging Item in Auto Layout
  • March 14, 2025
  • 24 views
MonicaS
Is this possible with Auto Layout?
I want Auto Layout to wrap but I want the hanging item/card if there is one to be center aligned versus left aligned.
Raphael_M
  • March 14, 2025
Hi, Monica.
There’s not enough for context regarding your question. 😅 But in auto-layout you can’t set constraints unless you put it on absolute position.
MonicaS
  • March 14, 2025
I figured it out. I needed to change the alignment choice in the Auto Layout. When I tried it the first time, the cards were too wide for some reason when it was center alignment versus left and it went straight down but when I tested it with just textboxes with the letters A, B, C, through G, it worked.
