Cannot scroll to the left without triggering backspace
  • June 20, 2024
  • 4 replies
  • 458 views
This is a new problem – recently when I try scroll to the left on a FigJam on my Mac trackpad it triggers backspace, so am constantly accidentally exiting the board. Resorting to switching between the select and hand tool to navigate but the shortcut keys for them are difficult to reach on my keyboard (V and H). I’m on macOS Sonoma 14.2.1.
Best answer by Vishal_Ramawat
If I understood it correctly, the trackpad causes the browser ‘back’ action and you exit?
On regular websites do you use double finger swipe to navigate back? If yes, you can disable that and see if it helps.
You can turn off trackpad gestures on a MacBook by going to Apple menu > System Settings (or System Preferences) and clicking Trackpad > More Gestures
Vishal_Ramawat
Vishal_Ramawat
Did it work? If so, please mark the answer as Solution 🙂
Yes it did, thank you very much! I think I’ve marked it solved now
Mathias_Abdissa_Mengesha
Thank you Vishal. I was unable to scroll left with my Mac trackpad I was trying to use hand tool but After this It have worked well now.
Thanks again.
