Hayley Johnston
Jan 29, 2025 6:25 PM UTC
Cannot Publish Components in Figma Slides
I received this alert for the first time today since working in Slides. It will no longer allow me to publish templates with components included on my slides. See the screenshot of the error. I don’t know if this is a glitch, but yikes! This is not good. Is anyone else having this error?
Jan 30, 2025 2:04 AM UTC
Hi ​@Hayley Johnston ,
Could you please provide a bit more detailed explanation of the steps you followed so that we can attempt to replicate the issue?
Thanks for your patience.
Toku
Hayley Johnston
Jan 30, 2025 4:19 PM UTC
Hi Toku!
Yes, absolutely. I was utilizing Figma Slides, copy and pasting in slide sized frames from a Figma Design file. The frames included both “components” and other design elements. I had no trouble bringing those frames into Figma Slides, but when I finished editing the slides, it wouldn’t let me publish because I had “components” on my slides - see the error above again for reference on how they worded it. The “components” in question were logos and a copyright label.
I tried physically moving them off the slide, I tried using the eye tool in layers to hide them and then also lock them, and what ultimately ended up working was going through every slide and detaching every instance of a component. It meant what it said, no components haha. While ultimately fixable, it seems like components are such a back-bone feature of Figma that it almost felt like a glitch, and I’ve published multiple templates that contained components before, so it’s a first time occurrence for me!
Hope this helps clears it up, happy to help answer any more questions!
Thanks!
Michel_Schafer
May 9, 2025 12:55 PM UTC
Hi ​@y_toku I had the same problem and found the solution. Only instances may be in the slides, no main components themselves - not even outside the ‘slide area’. Simply place the main components in other FigmaFiles.
