I have a file I created in my personal account; company bought a Pro account and I transferred it there by changing the owner to me at my company address.
It is in Recents. l can’t drag it into the team I created (the team doesn’t highlight on drag hover), and if I create a project under the team and try to drag the file there I get a message “You don’t have permissions to remove files from this project.” Huh?
Best answer by Chris_Ryan1
Log in as [destination account email] and upgrade [original account email] to be an editor on the [destination team] (this will only be temporary). → Manage team permissions
Log into [original account email] and move all files that you wish to work on using Professional features into [destination team]. The simplest way will be to consolidate all of those files into one project, and then drag and drop that project into [destination team] using the lefthand sidebar. You may also want to move the draft files of [original account email] as well → Move files between accounts, organizations, teams, and projects
Once moved into the [destination team], right-click each of those files > Share, and invite [destination account email] to each file as an editor. Do the same for any project(s) you moved → Invite to projects, files, and prototypes
Log in as [destination account email], and accept each of those file invitations.
Return to your [original account email] account, and change [destination email]'s role from editor to owner → Transfer ownership of files or projects
Once you’ve moved and transferred ownership of all files, log back in as [destination account email] and open the team’s “Members” tab. From there click the ••• next to [original account email] and choose Remove. *Don’t forget this step of removing [original account email] from being an editor on the team. Leaving that user as an editor will create a $15 additional to your subscription.
I ended up saving the file as .fig file, importing it again, and then moving to the correct Team by right clicking and selecting “Move to”. Dragging to the sidebar didn’t work.
Hi, here is my solution.
Make a copy of the layout, adding it to the draft.
After that, go to the home page then drag and drop it to your development team.
Success!! Good luck!
Hi, i tried this and it doesn’t work, it says i don’t have permission. Meanwhile I’m already an admin with full access on the team. Originally I tried to drag the file straight to the team folder, but it doesn’t give any response not even error message. Do you happen to know any updates on how to do this? Thanks
Hey @Diastuti_Arnumsari1, sorry to hear you’re having trouble trying to move a file!
You mention that you have full access to the team, but do you also have can edit access permissions for the destination project? Access to files is determined by editor access on the team, project, or file itself. As an Admin, you don’t get automatic permissions to all projects.
More info regarding access you need to move a file available here:
I have a related but different problem. I am the owner of a few files and have a team with two members. I am the admin of the team. I upgraded to a professional account and I do not see my files in Draft. I can find them in recent history and when I try to move them, the “Move” button is grayed out. So, I’m unable to move the files to draft or in a new project.
What is happening here and how do I access my own files without having to find them in Recents?
Hey there, sorry to hear you are also having issues with your files! I see in the backend that our technical specialist is investigating your issue (as the behaviour isn’t intended on your end). Please continue the conversation via email so they can help you out!
I am having the same problem as in the recent post.
I was been waiting for a reply to this thread but cannot find out the outcome.
How can I get support?
Problem is almost identical to my most recent post and is as follows.
-Files passed in ownership transfer only appear in Recents.
-The ”Move” button is grayed out and cannot be pressed.
yeah definitely it is a bug, you ask us to move all file drafts to make more money, but you are not ready on the basic functionality. I have the same issue here…
