Semi_Design_UED-MED
Jun 29, 2023 3:22 AM UTC
Can I use FormData API in plugin sandbox?
When I use FormData to send a network request to pass a file, I encountered the following error. Can Figma support FormData in sandbox?
fetch API is ok to send file, but it need to change my previous file upload interface.
Karl_Koch
Jul 4, 2023 6:56 PM UTC
I’m going to assume you’re attempting to fetch data in code.ts. In this case, you’re trying to access browser APIs in a file that only knows about Figma APIs.
Try moving your logic to your UI file and then pass the response to code.ts via a postMessage.
Semi_Design_UED-MED
Jul 20, 2023 11:56 AM UTC
Thanks you a lot. In dev mode codegen(recent supported by Figma) panel, sandbox can not communicate with ui.
tank666
Jul 20, 2023 2:07 PM UTC
Actually you can. Just call the invisible UI to access the Browser API.
Semi_Design_UED-MED
Jul 24, 2023 3:58 AM UTC
When I called figma.showUI before, there was an error, thank you for your reply, I will try again.
Semi_Design_UED-MED
Jul 26, 2023 1:57 PM UTC
Works!! figma.showUI can pass visible: false.
figma.showUI('xxx', { visible: false });
