기미르
Dec 9, 2025 5:02 AM UTC
Auto layout issue
If you look at photos 1 and 2, the auto-layout is hanging.
If you modify the text in that state, the length of the figure should change according to the length of the text, but it hasn't changed. Why doesn't the length change when the auto-layout is hanging?
Nellya
Power Member
Dec 9, 2025 9:01 AM UTC
Hi. Make sure the auto layout width is set to Hug, not Fixed
기미르
기미르Author
Dec 9, 2025 10:02 AM UTC
Thank you. I checked the problem, but do I have to set it as a hug every time I call auto layout? I want to change the default value
Nellya
Power Member
Dec 9, 2025 11:11 AM UTC
It’s actually hug by default for me, not sure why it was fixed in your case. Did you change the width after auto layout was applied?
기미르
기미르Author
Dec 9, 2025 1:17 PM UTC
I didn't apply the width separately, I just modified the text after applying the auto layout, but that's what happened. You're saying that I still have to set it as a hug until now, but there's no way, right? ㅠ.ㅜ
Nellya
Power Member
Dec 9, 2025 2:41 PM UTC
I mean hug  should be the default after applying auto layout. If it isn’t, you’ll need to manually set it to hug
