yoshio
Aug 21, 2024 8:58 AM UTC
Arrowheads in arrow images are missing
Hi all.
The following arrow design was created.
IMG__Arrow1
exportAsync() was used to retrieve the arrow image.
The following image shows it.
IMG__Arrow1
How do I get an image that is not missing?
yoshio
yoshioSolution
Aug 22, 2024 8:24 AM UTC
Thanks Gleb , James_Yang.
It was very valuable information.
I was looking for a solution myself, and I found it.
The cause was the useAbsoluteBounds:true option.
  • success
let bytBmp:Uint8Array = await node.exportAsync({format:‘PNG’});
  • Failure
let bytBmp:Uint8Array = await node.exportAsync({format:‘PNG’, useAbsoluteBounds:true});
Power Member
Aug 21, 2024 9:28 AM UTC
This definitely seems like a bug. As a workaround you can wrap this arrow in a larger frame.
James_Yang
Aug 21, 2024 10:32 AM UTC
This snippet of code will export an arrow and put an image of it right next to it. The entire arrow should show up:
(async () => {
  const node = figma.currentPage.selection[0]
  const renderBounds = node.absoluteRenderBounds
  // Export a 2x resolution PNG of the node
  const bytes = await node.exportAsync({
    format: 'PNG',
    constraint: { type: 'SCALE', value: 2 },
  // Add the image onto the canvas as an image fill in a frame
  const image = figma.createImage(bytes)
  const frame = figma.createFrame()
  frame.x = renderBounds.x + renderBounds.width + 20
  frame.y = renderBounds.y
  frame.resize(renderBounds.width, renderBounds.height)
  frame.fills = [{
    imageHash: image.hash,
    scaleMode: "FILL",
    scalingFactor: 1,
    type: "IMAGE",
Result:
yoshio
yoshioAuthorSolution
  • success
  • Failure
