AI's features activation
  • June 2, 2025
  • 141 views
Chuck_97
How to remove or turn off an AI option attached to a frame ? Or to see in the design settings if AI tools are actively used in the selected element ?
For exemple, I was trying “Replace content” in a frame, when I dupplicate I now can only do “Duplicate with new content” and can’t turn off the option, even when removing the autolayout and putting it back.
Best answer by Chuck_97
Hello, I found the solution, to deactivate the option of “Replace Content” you have to replace the changed frame with the original one, or quickly click on “cancel” near the tool bar.
I still haven’t found where to remove completely AI from the frame without doing an action that trigers it and click on “cancel” after.
  • Figmate
  • June 3, 2025
Hi ​@Chuck_97,
I understand you're seeing a new placeholder text when you duplicate a layer that already has placeholder text using "Replace Content," and you're looking for a way to turn this off.
I've tried to replicate this behavior on my end but haven't seen the same thing so far. What I observed was a banner suggesting the use of "Replace Content," but it didn't automatically create a new placeholder in the duplicated layer, as mentioned in this article.
I might be misunderstanding what you're seeing, so could you please share a video recording demonstrating this behavior? Please include your full Figma screen in the recording. This will help us understand exactly what you're seeing and how we can best assist you.
Chuck_97
  • June 3, 2025
