About Mask
  • June 21, 2025
  • 32 views
Erin Wu
Hi,
I'm using the browser version, but I don't know why my mask effect isn't working. Could it be because I'm still on macOS Catalina?
Just wondering if the OS version might be causing the issue.
Tom Reem
  • Figmate
  • June 22, 2025
Hey ​@Erin Wu — welcome to the Forum 👋🏻 and thanks for bringing this up!
I took a closer look, and it’s possible your OS version might be causing the issue. Figma requires macOS 11 (Big Sur) or later to run smoothly. You can double-check the minimum system requirements here: Browsers and operating systems.
If updating doesn’t do the trick, let me know if you’re seeing any specific error messages or if you can share a screenshot of what’s going wrong — along with a note on what you’re expecting to see happen. You could also try downloading the Figma Desktop app to see if that moves things forward.
Hope this helps — keep me posted on how it goes.
