500 errors occurred when I was using the API
  • February 29, 2024
  • 7 replies
  • 457 views
zhangbre
Hello, 500 errors occurred when I was using the API.
curl --location 'https://api.figma.com/v1/files/xxxxx/variables' \
--header 'X-FIGMA-TOKEN: xxxxx' \
--header 'Content-Type: application/json' \
--data '{"variableCollections":[{"action":"DELETE","id":"VariableCollectionId:555:23333"}]}'
The response result is:
    "status": 500,
    "error": true,
    "message": "Error updating file, please try again later"
I remember a few months ago, this was working properly, and the query was normal.
The same situation applies when adding variable data, with a status code of 500.
  "variableCollections": [
      "action": "CREATE",
      "id": "my_variable_collection",
      "name": "BRE_New_Variable_Collection",
      "initialModeId": "my_mode1"
  "variableModes": [
          "action": "CREATE",
          "id": "my_mode1",
          "name": "chinese",
          "variableCollectionId": "my_variable_collection"
          "action": "CREATE",
          "id": "my_mode2",
          "name": "en",
  "variables": [
          "action": "CREATE",
          "id": "my_variable1",
          "name": "bre账号名",
          "resolvedType": "STRING",
  "variableModeValues": [
          "variableId": "my_variable1",
          "modeId": "my_mode1",
          "value": "张三"
Thank you for your review. If there is a solution, please let me know. Thank you very much!
  • February 29, 2024
I have the same problem, the write api cannot succeed 😒But read api will work
Harsha_Hassan_Ravindra
Is there any updated on this?? our team is facing the same issue 👀
  • March 5, 2024
Thanks for the post. I’m checking this with our internal team. We will get back to you when I have anything that I can share with you.
Thanks for your patience.
Toku
  • March 5, 2024
Hi all,
I’ve checked with our engineering team and they confirmed it was a bug and they’ve already fixed it. Could you please try again and let me know how it works?
Thanks!
Toku
Batchelor_AM_Amelia
Hi @y_toku, this seems to be an issue again. I can successfully read files, however receive a 500 error and “Error updating file, please try again later” in response to a POST request. Even on the Figma documentation page itself. I’ve had this issue since at least 28th March '24. Any help would be greatly appreciated.
  • April 2, 2024
Thanks for flagging. I’ll check internally again and will get back to you if there is anything I can share with you! Thanks
  • April 10, 2024
Hi there,
Our internal internal team confirmed it’s fixed. Could you check? If you still have the issue, please let us know.
Thanks!
Toku
